November 19, 2002, 03:43 |
turbulence covergence
Hello.
After getting the solution, I am facing a difficulty in judging that the particular set of input turbulence parameters (example; Dissipation length scale & Turbulence intensity in standard K E modal), being selected are correct. For this, should I check the residuals of turbulence only or do I need to check something else. I will appreciate your guidance in this regard IRFAN |
November 19, 2002, 19:47 |
Re: turbulence covergence
If you have an experimental data for the case, you can adjust that value. If not, you can only use default value. How aout using RNG K-E model?
Sudden non covergence of k-e | Anastasios | FLUENT | 2 | January 27, 2008 07:06 |
turbulence:turbulence viscosity vs kinetic energy | sam | FLUENT | 0 | June 25, 2007 23:51 |
Turbulence%+Dh | abel | FLUENT | 3 | April 12, 2005 18:19 |
turbulence | abdou | Main CFD Forum | 5 | February 12, 2005 06:22 |
HELP! TURBULENCE k-e OR k-omega TURBULENCE MODEL? | Mirek Kabacinski | FLUENT | 5 | August 24, 2003 22:31 |
