How does PLANT add codes into ground?
Old   December 3, 2002, 01:34
Default How does PLANT add codes into ground?
ZHANG ZHIQIN
When I run PLANT and add some formula into it and then exit, some codes are added into Q1, then I set the Earth to PRIVATE and compile the ground and earth, link them. But when i open ground, it is still empty, why? thanks for your advice.
Old   December 17, 2002, 08:56
Default Re: How does PLANT add codes into ground?
H.Tang
set MSOG=T in Q1 file
Ground Coding Using PLANT Alex Phoenics 1 January 23, 2009 07:52
CWM Plant. Gaurav Bagadia FLUENT 0 March 10, 2007 03:45
about plant galary Phoenics 0 August 9, 2003 06:05
How to add new code in ground with PLANT? Zhang Zhiqin Phoenics 2 April 30, 2003 12:45
How to use plant? wright Phoenics 3 March 26, 2003 08:23
