Does boundary coincide with node or wall
Old   April 12, 2006, 13:46
Default Does boundary coincide with node or wall
K SANJAY
I would like to know whether the boundary coincides with cell node or cell wall in a typical 1-Dimesional uniform gridding in PHOENICS.
Thanks in advance
Sanjay
Old   April 13, 2006, 06:03
Default Re: Does boundary coincide with node or wall
Mike
The boundaries of the solution domain coincide with the cell faces. Cell nodes are not stored at the domain boundaries, only between the centres of the cell faces.
Old   April 13, 2006, 06:18
Sanjay
Dear Mike! Thanks for your clarification. If I know cell centre values, I hope I can get the values at cell faces using east(indvar), in case of east face. To call this value, what exactly should be the command to be used in ground? Thanks in advance. regards, Sanjay
Old   April 21, 2006, 17:30
Michael
Scalar variables are stored at cell centres, and the velocities at cell faces. If you want the values of scalar variables at the cell faces, then these would have to be obtained by interpolation from the surrounding nodal values.
the fisrt node on the mesh edge to the wall Selina FLUENT 0 March 14, 2009 07:12
non-manifold boundary at node ??? Mark CFX 0 March 22, 2007 10:07
node distance from wall?? Fluuuent FLUENT 0 April 5, 2006 17:37
near wall first node justin Main CFD Forum 0 February 4, 2006 08:01
distance of first node to wall Thorsten CFX 0 August 30, 2005 02:53
