January 22, 2008, 08:09 |
Convergence
Hi, Wonder if anyone can give me some tips on how to get your simulation to converge? I assume the mesh quality is essential for convergence? Also how do you know if its converged? If it flatlines can you assume it has converged? Any help would be great thanks!
January 23, 2008, 06:14 |
Re: Convergence
January 25, 2008, 12:13 |
Re: Convergence
I've found that convergence varies widely with the types of models you're using and the types of simulation you're trying to run. For instance, I've found that combustion models benefit from the use of the (old) SARAH setting.
March 18, 2008, 17:15 |
Re: Convergence
Hy,
Linear relaxation should be used for Pressure and ke / ep. I found 0.4 for P1, 0.3 for KE and 0.4 for ep work nice for much cases. Velocity relaxation depends much on the cell diameter and the velocity in the smalles cell. Choose the velocity relaxation factor as a false time step equal or lower than the shortest time the flow needs to cross the cell. Example: For a cell of 100mm and a flow speed of 10m/s the relaxation factor has to be lower than 0.01 Temperature relaxation can be a factor of 10 - 50 higher than velocity relaxation. Most problems with relaxation come from small cells or a bad grid. Try without parsol and use higher tolerance to find problems. best regards, ef |
May 6, 2008, 15:45 |
Re: Convergence
Yes, this is consistent with what I've found (though I've never used parsol with chemkin) - thanks for the summary!
Patti |
URF and convergence in natural convergence | Marie-Anne | Main CFD Forum | 11 | September 11, 2009 10:07 |
convergence | vijay | FLUENT | 6 | February 1, 2006 03:04 |
convergence | vijay | Main CFD Forum | 1 | January 30, 2006 13:13 |
too bad convergence | Davoche | Main CFD Forum | 2 | November 20, 2005 05:08 |
About convergence | LQ | CFX | 3 | June 2, 2005 23:43 |
