April 16, 2008, 08:08 |
Constant temperature boundary
I have done several problems in PHOENICS. I have seen that the constant temperature boundary does not work as it should. For example if a body with constant temperature is kept in the path of flowing air and the temperature of the air is not the same as the body, the body temperature will slowly reach to the air temperature. Why does this happen? Bye Ananta |
April 22, 2008, 11:25 |
Re: Constant temperature boundary
Is this a steady or unsteady analysis? How are you fixing the temperature of the body?
April 23, 2008, 01:24 |
Hi Mike,
This is steady state only. I am fixing the object temperature through 'fixed temperature' option.... With regds, Ananta |
June 5, 2008, 09:24 |
Hi Ananta, Use INFORM sources and specify the thermal boundary condition. Also, check out Library Case #629 "Flow over heated bricks - Steady" for additional references.
Best Wishes, Allen *********ACS Consulting - US Distributor of PHOENICS**** www.cfd-consulting.org |
Constant heat flux with uniform temperature | Jake Lee | FLUENT | 2 | April 13, 2011 22:08 |
bc/wall/thermal - temperature not-constant? | martin | FLUENT | 5 | March 1, 2009 11:33 |
urgent: Combustion constant temperature | Tim | Siemens | 3 | June 29, 2008 18:12 |
heat transfer with constant wall temperature | Marco | FLUENT | 0 | December 8, 2005 07:16 |
transient temperature field with constant velocity | Törnquist | CFX | 0 | September 16, 2003 04:22 |
