September 16, 2014, 15:22 |
Boundry conditions for O-grid mesh
saad
Dear All,
Using pointwise, I have created hyperbolic O-grid topology 2d mesh for airfoil, now for boundry condition, what I am doing, is to split the outer circle into two semi curves (for velocity inlet and pressure outlet) Is this right approach?? or there is other way around? kindly help my solver is ansys fluent Thanks |
September 17, 2014, 09:57 |
Chris Sideroff
Rep Power: 22 |
That depends on the type of gas model you are using. If you are assuming a compressible flow (ideal gas), Fluent has a characteristic boundary condition call "farfield" where you set the freestream conditions. This boundary condition type would allow you to use the whole circle.
However, this boundary condition can not be used for incompressible flow (constant density). Therefore, the approach you are using would be appropriate. |
December 30, 2018, 17:13 |
Bidesh Sengupta
Rep Power: 7 |
Hi!
What shall be BC in case of openfoam? |
January 3, 2019, 12:16 |
Travis Carrigan
There's a "freestream" and "freestreamPressure" type you can use with OpenFOAM. You'll just need to specify a "freestreamValue" and you're good to go.
January 4, 2019, 03:00 |
Bidesh Sengupta
Rep Power: 7 |
Thank you very much. It was successful.
February 9, 2020, 01:37 |
O grid mesh boundary condition in ansys fluent solver
Jay
Rep Power: 6 |
I used farfield as velocity inlet, airfoil as wall.. which boundary condition I give for sides?...This was the problem that I faced in ansys fluent solver.. can anyone help me?
February 9, 2020, 01:39 |
Jay
Rep Power: 6 |
I used farfield as velocity inlet, airfoil as wall for o grid mesh.. which boundary condition I give for sides?...This was the problem that I faced in ansys fluent solver.. can anyone help me?.. in ansys fluent I got big confusion what I give for sides?
February 22, 2020, 01:12 |
Jay
Rep Power: 6 |
hi!
what shall be BC incase of ansys fluent |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 05:39 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
