Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
Circle deflection
Old   February 7, 2017, 21:55
Default Circle deflection
saeed
mollaee.saeed is on a distinguished road
Hello everybody:
I am trying to mesh a shape in which there is a circle, but when I want to mesh a quarter of the circle (picture 1) it deflects after meshing and is converted from a curve to a line (picture 2)
does any body have any idea?
Thanks for your help
mollaee.saeed is offline   Reply With Quote
Old   February 8, 2017, 17:45
Zach Davis
RcktMan77 is on a distinguished road
You might select the connector in question, and from the Grid menu select Distribute.. On the Break Points tab ensure there aren't any Break points that are preventing the linear portion of your connector from being dimensioned with grid points. If there are, as I suspect, then simply expanding the Delete Break Points frame and clicking on the Delete Break Points button should resolve the issue for you.
RcktMan77 is offline   Reply With Quote
Problem with circle sampling type, of Sample utility nik OpenFOAM Post-Processing 4 May 29, 2017 05:27
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 16:16
Equation for a rotating circle outside the origin mali28 Main CFD Forum 0 November 14, 2014 06:38
Subtraction of a circle from a rectangle,Gambit engahmed ANSYS Meshing & Geometry 2 May 17, 2010 01:08
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 01:04
