July 11, 2017, 07:21 |
Triangles are degenerate Pointwise
Rep Power: 8 |
I'm trying to initialise a block and at first I had intersecting triangles because the equiarea skewness of some cells was too high. However, after fixing this problem the block can't still be initialised and I get the message "Triangles are degenerate". Can anyone help? Thanks |
July 11, 2017, 12:28 |
Rick Matus
Will need some more information to help with this. Can you share your Pointwise project file. If you can't share the project file, can you post some pictures of the problem area and cut and past the full error messages from Pointwise?
What is your maximum equiarea skewness now? How did you make the surface mesh, e.g. isotropic or T-Rex, all triangles or mixed quads and tris, etc? Rick |
July 11, 2017, 12:40 |
Rep Power: 8 |
My surface mesh is an unstructured one (just triangles). I can't post pictures right now, but I can tell you that my maximum equiarea skewness is now below 0.7. Do you think I should try to decrease it even more?
Just some more info until I post some pictures, what I'm trying to do is initialise a block between an inner cylinder and an outer cylinder (this one is an annular cylinder, of course). |
July 11, 2017, 13:55 |
Rick Matus
Skewness below 0.7 everywhere should be fine.
How large are the surface triangles compared to the size of the gap between the inner and outer cylinders? How was the block constructed? Does it have two faces with the inner cylinder as one face and the outer cylinder as the other face? Rick |
July 13, 2017, 11:08 |
Rep Power: 8 |
I solved the problem and I'll post it just in case someone else needs it.
When getting the triangles are degenerate error, you get the coordinates of the points of the triangle that it is causing that error. One way to solve this problem is locating this triangle and smoothing the surface mesh around that area. |
hybrid mesh created by pointwise fails mesh check in fluent due to left-handed faces | Hamid.de | Pointwise & Gridgen | 4 | November 9, 2016 11:20 |
[Commercial meshers] Pointwise to Foam - cyclic BC points order | Pj. | OpenFOAM Meshing & Mesh Conversion | 5 | August 14, 2016 04:47 |
CAD for Pointwise import | giangcoikx | Pointwise & Gridgen | 1 | July 19, 2016 10:59 |
[Commercial meshers] Native OpenFOAM interface in Pointwise | cnsidero | OpenFOAM Meshing & Mesh Conversion | 41 | May 20, 2012 18:30 |
Native OpenFOAM interface in Pointwise | Chris Sideroff | Main CFD Forum | 0 | January 16, 2009 12:37 |
