September 22, 2017, 01:15 |
Geometry is modified by pointwise
Bal Krishan
Rep Power: 8 |
Hello friends,
I m importing . IGES file to generate the geometry and then meshing in pointwise but when I am importing, pointwise converting one very important curve into series of line segment thereby completely changing the geometry so , my question is why is it happening an how I can correct it ? Sent from my Lenovo P1ma40 using CFD Online Forum mobile app |
September 25, 2017, 10:27 |
David Garlisch
Location: Fidelity Pointwise, Cadence Design Systems (Fort Worth, Texas Office)
Are you sure the application that created the IGES file didn't change the curve during export?
What is the "From File" model size (File, Properties...) after import? Did you try forcing different import model sizes? After selecting the IGES file for import:
September 25, 2017, 12:12 |
Bal Krishan
Rep Power: 8 |
I am not able to resolve this problem , so please look into this IGES file I am attaching with.
https://drive.google.com/open?id=0B2...0RFWC0yR0dYWTQ Some images are also attached, this is what i am exactly facing. If you need any other information, please ask Thanks for giving your valuable time Regards Bal Krishan |
September 25, 2017, 12:30 |
David Garlisch
Looking. Which curve is the one being converted to line segments?
If you have it, try importing the original solidworks file. FYI, this is what the IGES importer logs: Code:
Summary of IGES Parser: File : 11.TOP_Nozzle_VolvoS1_OSTLUND_SegmentDesign_KS3.IGS Date : Mon Sep 25 11:14:44 2017 Read Time: 0.05 secs Name : 11.TOP_Nozzle_VolvoS1_OSTLUND_SegmentDesign_KS3a Timestamp: 170921.164547 Author : Bal Krishan Org : Preproc : SolidWorks 2013 System ID: SolidWorks 2013 IGES Spec: 5.3 Units : M Tolerance: 0.000000 Max Coord: 499.990000 Summary of entities in IGES file: Type Form Count Unparsed Errors Description ------ ------ -------- -------- -------- ----------- 100 0 8 0 0 Circular Arc 102 0 24 0 0 Composite Curve 110 0 56 0 0 Line 120 0 2 0 0 Surface of Revolution 124 0 4 0 0 Transformation Matrix 126 0 60 0 0 Rational B-Spline Curve 128 0 10 0 0 Rational B-Spline Surface 142 0 12 0 0 Curve on a Parametric Surface 144 0 12 0 0 Trimmed (Parametric) Surface 314 0 1 0 0 Color Definition ------ ------ -------- -------- -------- ----------- 189 0 0 |
September 25, 2017, 12:39 |
Bal Krishan
Rep Power: 8 |
I have attached the image of converted part, Please check
White colored curve is not same as in the CAD image |
September 25, 2017, 12:43 |
David Garlisch
There is nothing wrong with the geometry.
The curves in the corner are so small compared to the farfield curves, that the default render settings are creating a segmented appearance! To fix the visuals:
The actual curves are NOT segmented, they are just being drawn that way. All calculations are done accurately with the actual, precise curve and surface entities. Be sure your graphics are set to double precision in Edit, Preferences..., Graphics. |
September 25, 2017, 12:50 |
David Garlisch
This database has extents of around 30 units (See Defaults tab). And the smaller bits in the corner are only around 0.01 units!
Assuming this is the complete geometry you will be meshing, I suggest that you set the model size to 100 or even 10 (BEFORE importing the IGES file) the improve the overall accuracy of grid calculations. good luck See youtube: Using Model Size Examining Assemble Tolerance Using Units of Measure When Importing CAD Models |
September 25, 2017, 12:58 |
Bal Krishan
Rep Power: 8 |
hybrid mesh created by pointwise fails mesh check in fluent due to left-handed faces | Hamid.de | Pointwise & Gridgen | 4 | November 9, 2016 11:20 |
[Commercial meshers] Pointwise to Foam - cyclic BC points order | Pj. | OpenFOAM Meshing & Mesh Conversion | 5 | August 14, 2016 04:47 |
kOmegaSST without turbulence modelling of the flow around geometry | CFDnewbie147 | OpenFOAM Running, Solving & CFD | 7 | December 5, 2013 07:29 |
[Other] Modification of multi region heater tutorial geometry | mukut | OpenFOAM Meshing & Mesh Conversion | 2 | October 4, 2013 20:59 |
Geometry for Confined Circular Jet | Greatness | FLUENT | 0 | October 1, 2013 05:04 |
