[Pointwise]: How to get rid of a grid point that couldn't float when using the solver |
April 18, 2020, 09:53 |
Rep Power: 8 |
Hello
I am trying to use the solver of Pointwise to smooth the grid, however a particular point in the grid cannot float and hence, distorting it. How can I get rid of that point? * This is the initial grid. * This is the mesh after using the Solve command: final mesh All the edges were set to floating, but as you can see that blue pointing is causing that distorsion. Thank you |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 12:31 |
two point correlations on unstructured grid | LuckyTran | Visualization & Post-Processing | 0 | January 14, 2015 10:30 |
[snappyHexMesh] snappyHexMesh and cyclic boundaries | Ruli | OpenFOAM Meshing & Mesh Conversion | 2 | December 9, 2013 06:51 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
