Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
Markers Su2
Old   April 28, 2020, 04:37
Default Markers Su2
luca abergo
lucapegaso6710 is on a distinguished road
Goodmorning everybody,
I generated an hybrid mesh around a wing, set the boundary condition now I want to export the mesh in .su2 file. The mesh is saved correctly but not the name of the surfaces so I can't use it in the solver. I use pointwise 18.3
CAN U HELP ME PLEASE?!?
lucapegaso6710 is offline   Reply With Quote
Old   April 29, 2020, 11:15
David Garlisch
Location: Fidelity Pointwise, Cadence Design Systems (Fort Worth, Texas Office)
dgarlisch is on a distinguished road
It works for me. Can you clarify what is not working?
From exported SU2 file:
% Boundary elements
NMARK= 3
MARKER_TAG= BcINLET
MARKER_ELEMS= 400
 9   448 5426  212    6
 9  5426 5427  213  212
 9  5427 5428  214  213
 9  5428 5429  215  214
   ...snip...
 9   446  447 5786 5785
 9   447    7  485 5786
MARKER_TAG= BcOUTLET
MARKER_ELEMS= 800
 9   561 5065  136    2
 9  5065 5066  137  136
   ...snip...
 9  4170 4171  305  304
 9  4171  580   10  305
MARKER_TAG= BcWALL
MARKER_ELEMS= 6200
 9     0   14 1113  230
 9    14   15 1114 1113
   ...snip...
dgarlisch is offline   Reply With Quote
Old   May 4, 2020, 06:17
Default Still issue
luca abergo
Yes I don't have the connectivity in the SU2 file, I've tried also with a simple cube as u did but same results. Which version of pointwise are u using? did u install some extra plugin?
Thanks a lot in advance
Old   May 4, 2020, 10:36
David Garlisch
I used 18.3.
You need to provide more detailed information.
Please be more specific and attach a ZIP the cube PW file and the exported cube SU2 file. If the ZIP file is too large, upload to a file service such as dropbox.
Old   May 4, 2020, 11:09
luca abergo
Here are the files!
Old   May 4, 2020, 17:12
David Garlisch
The cube.su2 looks 100% correct for the BCs defined in cube.pw.
Unless you provide MORE information about what EXACTLY is going wrong, I cannot help you any more.
Please read this VERY CAREFULLY:
READ FIRST: How to give enough info to get help
Gmsh does not ouput SU2 markers from physical surfaces stewels SU2 4 May 17, 2023 05:15
Pointwise mesh BC -unspecified in SU2 boundary markers monika_1387 SU2 2 April 17, 2020 04:52
Introducing SU2 International Developers Society (IDS) fpalacios SU2 News & Announcements 1 June 17, 2019 22:38
CGNS Boundary conditions using SU2 denzell SU2 3 July 9, 2018 05:58
Markers and parts name in SU2 and ICEM for my own case McAero SU2 10 November 7, 2017 18:05
