Suggestions for improving grid quality while creating hybrid grid |
March 2, 2021, 06:20 |
isit12
Rep Power: 5 |
Dear all,
I have been trying to create Vertical Axis Wind Turbine (VWAT) 3D mesh using a hybrid meshing technique. I created structured mesh around the blade boundary layer with pretty much good quality. Then I tried to fill the remaining of the rotating domain with unstructured cells. In doing so, I created a block with help of outer unstructured rotating domain and structured domain around the blade. After creating the block, I tried the following to achieve a good quality mesh. 1. In size field, I altered decaying to 0.9 and observed the result. Also, I tried altering the background spacing. I applied grid influencer, with T-rex BC changed to 'Adapt'. Still the skewness in transition region between structured and unstructured grid didn't improved. 2. I tried creating T-Rex layer around the structured block then fill the other region with isotropic layer. Also, altered T-rex governing criteria like 'Growth rate, max layer, skewness criteria, isotropic seed layers'. That didn't work. 3. I tried altering aspect ratio of the pyramids formed on structured domain to 0.1 and 0.9. Both didn't work. I also used connector to make a connection between inner block and outer domain and manually created domain and then block for different section changing the spacing of connector. Still, the skewness didn't improved. |
April 3, 2021, 15:17 |
#2 | |
May 3, 2021, 11:07 |
isit12
Rep Power: 5 |
While creating a unstructured block on a structured domain ,I found that the structured domain need to have smooth transition of cells. Domain having high aspect ratio surface will create highly skewed pyramid thus generating low quality unstructured cells.
Thank you for your suggestions. |
September 14, 2021, 01:27 |
Edgar Alejandro Martínez Ojeda
Rep Power: 6 |
I made a structured mesh on blockMesh, OF. The blades are circular arcs and the mesh is parametrized: https://github.com/EdgarAMO/VAWT-structured-mesh
[ICEM] Dramatic decrease in Mesh Quality After creating Prism Layers? | pamstad | ANSYS Meshing & Geometry | 5 | December 5, 2019 03:23 |
Hybrid mesh quality | j_h_86 | Main CFD Forum | 0 | May 22, 2013 04:31 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 12:18 |
Grid Quality and the Solution | Faraz | Main CFD Forum | 4 | January 10, 2000 19:18 |
LES & grid quality | Ales Skotak | Main CFD Forum | 1 | July 23, 1999 10:46 |
