REEF3D 22.11 & DIVEMesh 22.11
REEF3D 22.11 (https://github.com/REEF3D/REEF3D/releases/tag/22.11) and DIVEMesh 22.11 (https://github.com/REEF3D/DIVEMesh/releases/tag/22.11) are released with a couple of additions and fixes. Make sure to use the newest REEF3D with the newest DIVEMesh (otherwise REEF3D will not work).
The full list of changes in REEF3D 22.11: x added filtered SGS models for LES (CFD) x fixed diff_scalar in ediff (CFD) x added guard for 2D FNPF state files that prevents crashes when restricting the print out domain (FNPF) x fixed a problem with wetting-drying algorithm (FNPF) x improved hydrodynamic coupling file format x added continuous file print out for hydrodynamic coupling x updated discharge gage to non-uniform grids and fixed some bugs (CFD) x fixed density calculation for sediment transport in air phase (CFD) x added topo vtp print out (CFD) x merged CFD and SFLOW sediment algorithms x added explicit algebraic Reynolds stress model EARSM (CFD) x added k-omega stabilization (CFD) x added SFLOW breaking viscosity x added PDE based sandslide algorithm (CFD) x added less conservative adaptive timestepping for non-uniform mesh (CFD) x updated sediment angle of repose calculation (CFD) x fixed sediment profile print out (CFD) x added STL support for SFLOW 6DOF x changed 6DOF geometry default print out to binary vtp x added sediment bed probes and lines to SFLOW x fixed time based 6DOF STL print out (SFLOW) x added ramp up function for 6DOF motion (SFLOW) x added sedimentlog to SFLOW x added mainlog to SFLOW The full list of changes in DIVEMesh 22.11: x fixed solid crash for NUG x added corner ghost cell update for periodicBC x RAM usage optimization x added support for continuous HDC file support x HDC memory allocation update |
Thanks for the good work!
