March 31, 2021, 03:55 |
Visualization of results for REEF3D
yangshihang
Rep Power: 5 |
Hi, REEF3D team
Thanks to your software. I use it to simulate sediment transport. Here some problem about using paraview. 1. In the view of velocity ,I only need water result .So I choose points by different "rho". Is there any more way to choose water points ?And I want to trace and ink the boundary of air, water and sediment. I need a picture like the paper, "Numerical modelling of pipeline scour under the combined action of waves and current with free-surface capturing"Fig.9. 2. Also about velocity , I want a velocity vector diagram, which has some arrows . Like this paper," Numerical Modelling of Arctic Coastal Erosion due to Breaking Waves Impact Using REEF3D"Fig. 4. Yang |
April 1, 2021, 06:10 |
Hans Bihs
1. The best way to visualise water only, is to use the "clip" filter in Paraview and selected "Clip Type"->"scalar". Then for the scalar, you use "phi", which is the level set function. The value has to be "0", i.e. the zero level set. Make sure to remove the tick from the "inverse" box.
2. For the vectors, select the "Glyph" filter. Both "Orientation Array" and "Scale Array" need to be set to "velocity". The vector type can be changed by selecting a different "Glyph Type". |
April 2, 2021, 01:13 |
#3 | |
yangshihang
Rep Power: 5 |
September 10, 2023, 02:41 |
Chitrangini S
Rep Power: 2 |
Hi Yangshihang,
I am also working on sediment scour simulation and am not able to visualize the scour on Paraview. I want to ensure that I am not making any mistakes in the control and ctrl files, May I request you to share your control and ctrl files? |
paraview, reef3d, sediment transport, visualization of results |
Different visualization between Fluent and ANSYS CDF post processing results | Gianmario28 | FLUENT | 2 | December 7, 2020 04:23 |
Validating the results of numerical modeling compared to the results of another model | ENG.AHMAD | FLUENT | 0 | June 22, 2020 16:49 |
bad heat transfer results with low y+ | me45 | OpenFOAM Running, Solving & CFD | 0 | April 29, 2020 11:56 |
interFoam simulation yields inconsistent results for alpha1 surface | Ralinus | OpenFOAM Running, Solving & CFD | 8 | January 13, 2014 08:54 |
Creating a tool to interpolate results | Luis Batista | OpenFOAM Running, Solving & CFD | 2 | April 11, 2013 08:15 |
