Multi-phase Simulation for Calculating Resistance of Boat
Old   February 20, 2019, 07:11
Default Multi-phase Simulation for Calculating Resistance of Boat
sriram
sriram9127 is on a distinguished road
I am running a Multiphase Flow(Air and Water) over a boat. I think I am Making some mistake in physics criteria.
How to
1. Give boundary level separating air and water.
2. Give water and air velocity.
3. View the water velocity profile as it crosses through the boat.
I want to view the pattern created by the water as it moves over the boat.
Suggest me correct physics criteria, I think the mesh is fine. Should I run this simulation as a steady state or unsteady state?
sriram9127 is offline   Reply With Quote
Old   February 21, 2019, 02:45
Default How to view wave propagation
sriram
It is a multiphase problem(air and water).
Initial velocity zero for both phase.
I want to run a simulation for 1m/s velocity of both phases and view wave pattern.
Please find the attachment. The residuals are converged, but I can't find the entire wave pattern. Give me some suggestions.
Old   March 5, 2019, 15:21
Hendrik Weber
HeWeb is on a distinguished road
Hi sriram9127,
I am not a pro with multiphase flow, but stupid question:
you know that there is a tutorial in the userguide for this kind of Sim?
I did it several years ago and I think it was for unsteady Simulations, but maybe it helps!
Cheers
HeWeb is offline   Reply With Quote
bubble diameter definition in multi phase flow boiling simulation FLUENT Abishek FLUENT 13 July 1, 2019 12:12
three phase simulation in fluent monababaei Fluent Multiphase 6 October 3, 2015 02:59
Resistance Simulation for High Speed Hull in Turbulence to Match Experimental Data PeiSan Fidelity CFD 0 September 3, 2014 00:08
(help) three phase simulation on fluent sincity FLUENT 0 July 20, 2011 00:19
a question about two phase simulation xck1986 OpenFOAM Running, Solving & CFD 0 June 16, 2011 11:00
