December 25, 2019, 21:22 |
Boundary conditions for a 2D ducted fan?
David
I have a ducted fan mounted on a wing. And I don't want to simulate its real geometry. How should I set the boundary conditions.
If it is 3D, I can use the rotor model to simulate the rotor without rotor geometry. And I can see the flow boosting effect across the rotor disk. But now I want a 2D simulation, is there any boundary condition I can use? like a baffle, the flow will be sucked in when the flow reach the baffle, and the flow will eject out when the flow leave the baffle? The flow will have a total pressure boost across the baffle? Thanks. |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
