January 18, 2001, 12:50 |
a better sensor
since a sensor returns the value of the surrounding cell, coarse grids again cause problems when comparing experimental data with data from cfd analysis....
has someone already written a macro or an external program, that does some interpolation on arbitrary vertices or sensors ? how do i quickly find out which cell encloses the sensor or a vertex that is not connected with the mesh ? regards, achim |
January 19, 2001, 15:39 |
Re: a better sensor
First if you load vertex data instead of cell data, then sensors do interpolate.
After you do a sensor,scan if you do a sensor,list it will tell what cell its in. |
Sensor- problem | W.A. | Siemens | 4 | June 1, 2006 10:53 |
OFILE SENSOR | guest7777 | Siemens | 0 | April 20, 2006 05:12 |
modelling for pressure sensor | simon | FLUENT | 0 | September 29, 2005 15:31 |
Sensor points | Aline | Siemens | 2 | August 16, 2004 09:52 |
A problem about the sensor points | Lee | Siemens | 3 | October 31, 2003 13:32 |
