MARS discretization scheme
Old   January 20, 2002, 22:49
Default MARS discretization scheme
raymond
Does anyone have some experiences with MARS discretization shcee? I have tried it in the buoyancy flow as suggested by STAR-CD manual. But at some locations I got negative value of temperature where I define the initial and amibient temperatrue is positive throughout the whole domain. When I changed to SFCD scheme, all look correct.
In the methodology manual, I could not find the detailed information about the MARS scheme, do anyone have the same experience with me and tell me what's the limitation of MARS scheme?
Thanks!
Old   January 28, 2002, 06:05
Default Re: MARS discretization scheme
Anton Lyaskin
As I remember, MARS scheme is advised for momentum equations. For temperature and dencity SFCD is recommended.
I use MARS for momentum and turbulence and whould like to know more about it, too.
Old   January 28, 2002, 19:57
raymond
Thanks for your suggestion!
But in the tutorial of STAR-CD, (10.1) It was suggested that the MARS is applied for UVW and T and DENS, and turbulence energy and dissipiancy are using UD scheme. Is there any other suggestion for it?
Old   February 1, 2002, 05:33
Anton S. Lyaskin
I've never tried MARS for T and DENS, I use SFCD for them. And for some problems I couldn't get convergence with UD for turbulence.
I've tried different schemes for a laminar flow in a square duct with 90 degrees turn. MARS makes little difference with QUICK.
Convergence in MARS scheme shiv Siemens 10 January 31, 2008 21:27
Help: MARS scheme does not converge! Jimmy Fox Siemens 6 August 8, 2007 10:08
Differencing Scheme MARS michael OpenFOAM Running, Solving & CFD 1 August 10, 2006 10:51
MARS Scheme Apurva Main CFD Forum 4 May 28, 2004 10:41
MARS discretization scheme pablo be Siemens 0 July 17, 2001 07:35
