converging-diverging nozzle
Old   May 27, 2002, 06:51
Default converging-diverging nozzle
seok Jang
Hi... I deal with converging-diverging nozzle(ISO 9300).
solution : 2D-compressible, steady-state, laminar
1) Nozzle throat diameter(d) = 4.48mm, inlet radius = 2d, nozzle length = 7.43d, nozzle expansion half angle = 4 degree.
2) Boundary condition : *Stagnation(upstream) : P=2e+05, T=20, direction=normal *Pressure(exit) : open air(P=0) *Symmetry *Wall : Np-slip
3)Thermophysical..... *Molecular Properties -density = Ideal-f(T,P) *Turbulence off *Thermal off *Refference data : press=1e+05, temp.=273, Cell NUmber=1(inlet point)....
there is no convergence after 1000 iterations.
What is the problem? Please, teach me. Thanks.....
Old   June 3, 2002, 11:50
Default Re: converging-diverging nozzle
Veebs
Check your Reynolds number. I guess you should have turbulent flow. Also you can reduce the Relaxation paraeters and check
VOF, Diverging or not? Renato Pacheco FLUENT 0 April 10, 2008 12:21
Converging then Diverging Residuals??? Erika Johnson FLUENT 8 September 19, 2006 10:45
Bluff body in converging/diverging channel Sergei Chernyshenko Main CFD Forum 0 August 11, 2006 17:11
Data on Converging-Diverging Nozzle; Mohammad Main CFD Forum 0 September 5, 2002 23:55
Converging-Diverging part Jungyoon hahm FLUENT 4 December 15, 2000 08:19
