How to put two models together
Old   July 12, 2002, 08:29
Default How to put two models together
Franch
I've two models. One is the inlet duct of a pump, the other is the inlet volume iside the pump.
So far, I've worked with the separetly: two models, two meshes, two simulation.
How can I put them together in one mdl file?
Geometries are very complex, so I cannot rebuild one of them in the other's mdl file.
Old   July 15, 2002, 06:03
Default Re: How to put two models together
Joern Beilke
Just search a little bit in this forum. It was discussed some time ago. (cdsave, cwri, vwri, cpwri, cread, vread, cpread). Or use the databases in proam.
Two-fluid models vs mixture models for bubbly flows Hansong Tang Main CFD Forum 6 December 8, 2009 03:21
MODELS Murthy V N FLUENT 0 February 9, 2008 01:48
LES models fran Main CFD Forum 1 August 25, 2005 06:44
MRF and DPM models you FLUENT 0 June 8, 2001 05:49
...models... Dia Zeidan Main CFD Forum 2 February 9, 2001 12:54
