March 3, 2003, 05:33 |
Residual value
Hi all~
I have a convergence problem. My model is 1/8 model of axial fan. Cell numbers are 620000. During iteration, the residual values are not decreasing. They are oscillated or very slowly decraasing. What's wrong with my problem or What I need to do? |
March 3, 2003, 11:15 |
Re: Residual value
I think it's the consequence of using the less accurate implicit MRF over the explicit MRF method. You are using the implicit method, right?
I did this last time: start from a low RPM, then stop. Restart with a higher RPM, stop after awhile, and then restart with a even higher RPM and so on, until you reach the RPM you want. It didn't really converge at my ultimate RPM but at least the residuals are a magnitude lower than they were (ie. 'good enough' for me...). I think you can you the advanced transient module's load steps instead of stopping and restarting so many times. |
PHI residual (using the old or new value ?) | Noel | Phoenics | 1 | March 3, 2009 06:22 |
No KE residual | kasim | CFX | 0 | March 12, 2008 16:43 |
Residual? | Beginner | Main CFD Forum | 1 | June 1, 2007 00:59 |
RMS Residual | Nikos | CFX | 1 | August 25, 2006 10:14 |
Residual | Beni | Main CFD Forum | 0 | September 24, 2005 17:48 |
