Grid Quality
Old   March 27, 2003, 07:33
Default Grid Quality
Andreas
I havenīt found StarCD's minimum requirements for grid quality. Do you know that? Aspect ratio? min. Angle? Warpage?
Thanks, Andreas
Old   March 27, 2003, 07:45
Default Re: Grid Quality
HVN
You could find that in the first chapter of the User Guide.
Old   March 27, 2003, 07:59
Andreas
Ok,
I've seen these parameters. But I think these are not the minimum requirements. Especially the internal angle with 45° seems to me very conservative.
Old   March 27, 2003, 21:14
cjtune
Well, if you can't improve your mesh quality any more (esp. tet quality <0.01), try running your case in double-precision and with the SIMPLISO algorithm. Should help lessen the effect of numerical errors from those badly-formed cells.
Old   March 27, 2003, 21:26
guang ai
I have the same feeling. Updating version is make computation more and more robust. Warpage up to even 75 degree does not incur trouble. However what happens to outcome? I did not make any comparison. Anyone has some idea?
Old   March 27, 2003, 21:40
cjtune
I once observed the difference in hex qualities: One model had near-perfect hexas and converged within 60 iterations while another (same geometry, differently meshed by a beginner) had an entire block (that I was able to spot) with *reflex* (>180'; probably around 190') angled cells and took 500+ iterations to converge. That model had 8 blocks of hexahedral cells.
Old   March 31, 2003, 11:32
roadracer
Exept for the time required to converge, were there any differences between the two calculations, and how big were them? Cheers Roadracer
Old   March 31, 2003, 12:14
cjtune
No other differences in set-up between the models. All block edge cell counts are fixed for this simple exercise. <10k cells as I remember.
Old   April 1, 2003, 02:59
roadracer
Sorry, I havenīt been clear, I meant if there were differences in the results!! Cheers Roadracer
Old   April 1, 2003, 03:40
cjtune
No idea. Never bothered to scrutinize it. Grid quality aside, the mesh was just too coarse (and hex dimensions will differ as positioning block edges is not an exact science) to achieve grid-independent results...
re: Double precision and grid quality Wooster CFX 5 July 26, 2007 10:10
grid sum and quality ? jieremy FLUENT 0 January 15, 2003 23:23
Grid Quality and the Solution Faraz Main CFD Forum 4 January 10, 2000 18:18
Grid quality in CFX4.2 P. Adamsen Main CFD Forum 2 November 25, 1999 12:32
LES & grid quality Ales Skotak Main CFD Forum 1 July 23, 1999 09:46
