Deference between underhood and engine cooling
Old   July 28, 2003, 22:15
Default Deference between underhood and engine cooling
therry henry
hay... anybody Is anybody know the deferences between underhood analysis and engine cooling analysis?
i confuse..
thank u.. best regard
terry Henry
Old   July 29, 2003, 08:11
Default Re: Deference between underhood and engine cooling
cfdweirdo
An underhood analysis focuses on the external flow within the engine compartment of a vehicle (and usually the external aerodynamics as well). Working fluid is air.
When you speak of an engine cooling analysis, it usually refers to the flow of coolant (anti-freeze), throughout the internal passages of the cylinder head, engine block, water pump, thermostat, etc... Working fluid is water/glycol mixture. Incompressible flow.
Good luck!
Regards, cfdweirdo ;-}
Underhood simulation Suresh Main CFD Forum 0 October 16, 2004 06:29
Regenerative cooling rocket engine Brian Main CFD Forum 0 November 12, 2003 06:59
another question about engine cooling system marivani Main CFD Forum 0 February 2, 2000 11:55
engine cooling system of vehicle marivani Main CFD Forum 1 February 2, 2000 10:57
