warning 007
Old   March 9, 2004, 21:22
Default warning 007
Jane
hi,everyone
what is this message means? "warning #007***setting T at cell 100 from 0.00 to 0.01 *TREF for density calculation." in this case, matirial is N2, and density set to f(T,P). there are other scalar O2,H2O. and for scalar calculation, the subroutine sorsca.f and fluij.f are used. can you tell me.
thank you so much
regards jane
Old   March 10, 2004, 04:15
Default Re: warning 007
Richard
It means something is going badly wrong with the enthalpy equation. There are lots of possibilities. Check your set up, especially relating to enthalpy (check specific heats, temperature boundary conditions). Try reducing the under-relaxation factors (if steady-state) or time-step and PISO controls. Look at the cells which cause the message: are they highly distorted, or next to badly matched couples?
Old   March 10, 2004, 20:25
Jane
thank you, Richard
i use the heat sourece subroutine sorent.f to add enthpy to some cells, and I set the density is f(t), but if i set it to other selection but not relating to the temperature.it will be ok, and there isn't warning like this. anyway, i think it must relate to the calculation of temperature, i will try to decrease the under-relaxtion fators. thank you very much!
jane
Warning 046, what does it mean? SAKTI Siemens 1 July 31, 2008 12:14
warning #064 ema Siemens 1 August 25, 2005 05:45
warning # 90 vishal Siemens 1 August 11, 2005 09:19
*** WARNING #052 *** Cirilo Siemens 1 July 27, 2005 08:34
Warning Paco Siemens 0 June 23, 2005 02:33
