May 8, 2004, 01:45 |
time-averaging transient results
Hello all!
I've been trying to search for a method in Star to time-average transient results for unsteady flows. I went through the archives and still reading after a few hours. Maybe this has been explained before but if you don't mind, kindly tell me how do this time-averaging of transient results this time. Is this available in GUI? If not, do tell. |
May 8, 2004, 15:44 |
Re: time-averaging transient results
This is an example of prostar macro which I got from Paco who works for the support team in Nürnberg.
The example I was working with had 107 time steps (beginning from iteration 2 and increments of 2): !First loading the pstt file! trload,druck.pstt,nomvgr,,c store,iter,2 !We could equally use the command getc, but if one does so, all the postregisters are cleared. oper, getc, su, 1 oper, getc, sv, 2 oper, getc, sw, 3 !Postregisters 1 to 3 are devoted to stored velocity components (in this example). We !then use postregisters 4 to 6 to store the sum of the different iterations. oper, copy, 1, 4 oper, copy, 2, 5 oper, copy, 3, 6 !Here we begin the loop for reading the remaining of iterations *define, noexe *set, increm, 2, 2 store, iter, increm oper, getc, su, 1 oper, getc, sv, 2 oper, getc, sw, 3 oper, add, 1, 4, 4 oper, add, 2, 5, 5 oper, add, 3, 6, 6 *end *loop, 1, 107, 1 !In our example the number of time steps stored were 107 oper, sdiv, 107, 4, 4 oper, sdiv, 107, 5, 5 oper, sdiv, 107, 6, 6 oper, inverse, 4, 4 oper, inverse, 5, 5 oper, inverse, 6, 6 |
May 8, 2004, 23:26 |
Thank you very much for your prompt response. I really needed something like this urgently.
I will modify this macro and inform you of my progress. I suppose the end-product of this macro is one post file? Can I save it with a different name? |
May 15, 2004, 15:03 |
It may be possible to activate the les averaging option (*.lesc files) for your case. I know you can do this with DES in 315.
I am not sure of the exact process, but I would say Copy your old problem file Turn on the les model with averaging and write the problem file (you may get some warnings regarding discretisation etc.). Check the differences, I suspect one of them will be the flag to activate averaging. You will have to make a edit by hand of the problem file for every case you want to do averaging on. Try these settings on a small model. It is worth a try. Steve |
May 18, 2004, 01:34 |
Interesting! Will try! At the moment too much work too little time...
Thanks for the idea! |
May 25, 2004, 09:09 |
you can do the avereging in the postdat soubroutine and compute any variable you want!
Time averaging results from a transient run | Flow Squad | CFX | 4 | October 24, 2011 09:11 |
how to use Transient Statistics/averaging results! | Houman | CFX | 4 | February 23, 2007 08:29 |
LES TIME-AVERAGING | Andy | Siemens | 3 | April 19, 2006 17:15 |
how to do time-averaging transient results | azmir | Main CFD Forum | 0 | May 8, 2004 05:53 |
How to determine the time averaging factor? | Hai-Wen Ge | Main CFD Forum | 2 | April 18, 2001 21:19 |
