Energy balance
Old   July 5, 2004, 00:39
Default Energy balance
Julie Polyakh
Does somebody know how to calculate energy balance at two cross sections (not inlets or outlets)?
Best Regards,
Julie
Old   July 5, 2004, 03:22
Default Re: Energy balance
Richard
In v3.20 there's a new thing called internal boundaries which can do this.
Old   July 5, 2004, 03:40
Julie Polyakh
And what about v3.150A?..
Old   July 5, 2004, 06:15
Thomas
what about calculating the enthalpy difference (cp *dT) between these two cross sections?
Old   July 5, 2004, 08:23
Julie Polyakh
Nice, but in my simulation Cp=Cp(T). Which Cp value should I take in such a case?
Old   July 5, 2004, 13:50
Panos
You can use the formula Cp=a+bT+cT^2+dt^3 where the constants can be found in any book of physics and chemistry or thermodynamics. hope it is helpful
Old   July 5, 2004, 13:52
4xF
You could try to write a macro for integrating between two surfaces mdot*Cp*T = H, where H is the enthalpy, T is the temperature, Cp is your local Cp(T) and m is the mass flux (mdot= rho*S*V, S is the surface, V is the velocity). Ask also your local support office, they MUST have a macro ready for that.
Old   July 6, 2004, 03:19
Thomas
yes ans you can also use the operate command for this. you have 6 post registers to do this operation, thast should be enough!
Old   July 7, 2004, 03:58
Julie Polyakh
Yes, Panos, I know. But there is also the chemical energy of unburned fuel that I have to take into account.
Regards,
Julie
Old   July 7, 2004, 04:00
Default OK. Thanks
Julie Polyakh
Energy Balance Harshad CFX 0 March 5, 2008 06:36
k-epsilon ENERGY balance Jeremie FLUENT 0 March 24, 2007 07:46
Energy balance? HP FLUENT 13 September 12, 2005 14:22
Energy Balance Cholo FLUENT 0 April 9, 2004 13:53
Energy balance Eric FLUENT 1 February 17, 2004 19:33
