star is not running the simulation in windows |
July 31, 2004, 19:40 |
Thanks for the help. Now I did as u guys said abt running star from windows and i selected user sub routines and also moving mesh case. In the star-CD launcher it says "Running stat" but where can I see the process running? Also in the C:\WINNT\system32\cmd.exe window it says warning : command execution error please check screen output for details starin.f compile error exiting starlink .............. .................. f77: error switch f is ambigious what is the problem and how can i get it fixed though it says running star. is my program running? is the simulation going on in the back ground?? Thanks in advance.. Arnab |
August 2, 2004, 02:40 |
Re: star is not running the simulation in windows
You should install the fortran compiler.
Running FLUENT in batch mode for Windows OS | Jake Lee | FLUENT | 7 | June 29, 2016 08:38 |
Problems with Gambit running on windows xp pro | Carlos Ruiz | FLUENT | 1 | February 27, 2009 05:04 |
STAR-CCM+ , Re-Running same simulation | MAB | Siemens | 4 | September 29, 2008 04:17 |
problems of running SGI codes in windows | baal | Main CFD Forum | 1 | August 16, 2005 22:16 |
