August 18, 2004, 12:34 |
URGENT, max number of cells
Hello StarCD Users,
I have a question: what is the biggest possible number of cells which can be solved in StarCD? 1 milion, 100 milions? Thank you |
August 18, 2004, 17:53 |
Re: URGENT, max number of cells
I don't know the maximum number, but I am running a problem now that has about 8 million cells on 10 processors. Currently Argonne National Labs is running a model that has 73 million cells but requires 114 processors. Unfortunately, not all of us have access to the government's deep pockets.
As a general rule of thumb, if you are running hex cells, it takes about 45MB for 100K cells to run. However, to mesh the cells, it takes about 100MB per 500k cells. Tom |
August 19, 2004, 10:36 |
Thank you Tom. So theoretically If I had a 2 processor pentiun IV with 2 GB of memory I could think about creating 1.5 - 2 millions of cells, is it correct?
August 19, 2004, 12:27 |
with this hardware it should be possible to create something like 8 millions or even more. but then there is a problem of decomposing it for parallel computing. for such a large case you would have to use 64 bit machine to decompose your case. it could be run on 32 bits but not decomposed.
Number of cells | Johnny B | FLUENT | 2 | March 17, 2010 04:00 |
max. number of cells | Muhammad Shakaib | FLUENT | 1 | January 24, 2006 18:30 |
how to monitor cells-urgent! | azmir | Siemens | 4 | July 5, 2004 06:40 |
SOS! HELP! max number of cells :( | Jas | Phoenics | 4 | February 14, 2004 10:12 |
Number of cells | Christian Holm | Main CFD Forum | 8 | February 20, 2002 07:37 |
