user subroutines
Old   September 15, 2004, 07:21
Default user subroutines
vladimir
I have a simple question. How to make velocity gradients available for user programming? There is something, in the 'nom.inc' file, like that the user must do it using prostar but nothing else. So I am wondering what I am suppose to do in prostar?
Regards
Old   September 15, 2004, 12:06
Default Re: user subroutines
steve
prostar has an "operate,gradient" command which will compute them for you. They are placed in the usual post data registers where you can work them like any other post data or write them to a file and read them into another program.
Old   September 16, 2004, 03:09
vladimir
You maybe misunderstood me. I know how to do it in prostar, but it would be a bit inconvenient after each iteration to run prostar, then get the gradients, save them to a file, read it from a subroutine, do my job with it repeat it all over again and again don't you think?
I don't want to do it as a masochist. I found out the gradients can be accessed in vistur.f subroutine but not in sorsca.f. Any ideas??
Old   September 16, 2004, 17:18
steve
call support, they can send you an example coding for the velocity gradients so that you can acess it from any routine
Old   September 17, 2004, 02:57
vladimir
It seems to be the only way. Thank you.
Old   September 18, 2004, 19:47
Sheila
CALL VELGRD(UG,GU,S,CX,SB,NFONE,KEY,URO,URSI,VISTG,DENG ,TEG,VISLAM,MON,ISTYP)
Where UG is velocity, GU is gradient.
Dont forget to dimension the variables. These should be in one of the files, cant remember which, probqably nom.inc.
Old   September 20, 2004, 13:40
vladimir
Thank you Sheila but I asked support in the meantime and got an answer. It can be done via a constant #11 by assigning 1 as its value within prostar.
regards
Old   October 12, 2004, 13:59
Ethan
Hi Valdimir, I am also interested in getting the velocity gradient during the computation. Can you elaborate what you have done ? Thank You very much.
-Ethan
User subroutines and STAR-HPC v3.2 Lars Ola Liavåg Siemens 0 August 17, 2004 01:56
User subroutines Meiring Siemens 5 January 17, 2003 00:14
User subroutines Mir Siemens 10 May 4, 2002 16:16
user subroutines in Star-CD Zeng Siemens 5 March 21, 2002 03:43
user subroutines in CFX Zeng CFX 3 March 19, 2002 19:35
