October 27, 2004, 16:50 |
Star Design to Star-CD(Prostar)
Hello All,
How can we export or transfer a model from star design to star-CD/prostar? Do we need to mesh or grid the model in star design before we export it or we can mesh it later in prostar after we have imported frm star design. Thanks in advance, AB |
October 28, 2004, 05:01 |
Re: Star Design to Star-CD(Prostar)
a) You have to mesh the model in STAR-Design b) You have to start a run with 0 iterations, so that the model file is written. Use an additional input file containing the pro-Star command: ITER,0
October 28, 2004, 05:42 |
It is also possible to export the geometrie in *.ezs Format and do the surface meshing in pro-surf.
October 28, 2004, 07:18 |
If you have a newer version of STAR-Design, you don't need to run for one iteration. Once you have a volume mesh you can choose "Solver preprocessing" from the Solver menu.
October 28, 2004, 11:11 |
in StarDesign (expert modus):
[...] solve,postprocess !by this command .dbs-file will be saved in the stardesign-directory in Pro-AM: dbase,open fromStarDesign.dbs ! open .dbs-file dbase,list |
October 28, 2004, 12:21 |
Thanks a lot for all the tips and tricks for exporting file from star design to star-CD (prostar) but when I follow all the methods, I am getting this error all the time... what is the reason for this, though I am able to export simple models but not my own model which comes up with this error..
ammbatch30421.exe- Application error the instruction at "0x00739c29" referenced memory at "0x09248ea8". the memory could not be "read". click on OK to terminate the program click on CANCEL to debug the program |
how to export a mesh from star design to star cd | aounallah | Siemens | 4 | March 6, 2009 06:22 |
from prostar to star-desing/post | cirilo | Siemens | 1 | July 13, 2006 02:33 |
Solve Sudoku using prostar/star v4: Excellent!!!! | Algo-dorak | Siemens | 2 | May 28, 2006 11:38 |
iges-prosurf-proam-prostar-star | elvis | Siemens | 6 | October 17, 2005 04:35 |
