Errors transferring file from starCD to StarCCM+ |
December 2, 2004, 09:55 |
Hello ,
I have saved a model file in star-CD V3.2 in star.ccm format and wanted to import this file to starCCM+. But when I import, I get the following error messages: Server Error: CcmImporter: could not open file: E:\ARNAB\star CCM+ solver\shock tube\star01.ccm Error: {Command=ImportFile} Annotation: Server Error: CcmImporter: could not open file: E:\ARNAB\star CCM+ solver\shock tube\star01.ccm Error: {Command=ImportFile} Server Error: CcmImporter: could not open file: E:\ARNAB\star CCM+ solver\shock tube\star01.ccm Error: {Command=ImportFile} at star.neo.NeoClient.execute(NeoClient.java:203) at star.neo.NeoClient.execute(NeoClient.java:98) at star.neo.NeoClient.execute(NeoClient.java:90) at star.neo.ClientServerObject.execute(ClientServerOb ject.java:349) at star.common.ImportManager.importFile(ImportManager .java:50) at star.common.ImportManager.importFiles(ImportManage r.java:57) at star.coremodule.actions.ImportAction$ImportGeneric Operation.performAction(ImportAction.java:85) at star.coremodule.actions.SimulationLockOperation$1. run(SimulationLockOperation.java:64) at org.openide.util.Task.run(Task.java:136) at org.openide.util.RequestProcessor$Task.run(Request Processor.java:330) [catch] at org.openide.util.RequestProcessor$Processor.run(Re questProcessor.java:686) Can someone tell me what the errors mean and how can I get rid of them so that I can successfully import the file. Thanks in advance, AB |
December 13, 2004, 16:26 |
Re: Errors transferring file from starCD to StarCC
It is probably either an incompatible version issue or a bug. Send the file to your support office, and use the ngeom format instead.
Chris |
Conj. Heat Transfer: STARCD vs. STARCCM+ | Stefano | Siemens | 0 | September 24, 2007 08:55 |
StarCD v4 *.pstt file problem | Rotan | Siemens | 3 | September 17, 2007 05:01 |
rotay cup atomizer in StarCCM+/StarCD | mic | Siemens | 2 | March 22, 2007 19:48 |
Meshing Errors in Starccm | Josh Kempenaar | Siemens | 2 | November 30, 2006 08:14 |
starcd cel file format | mark | Siemens | 0 | February 12, 2005 11:13 |
