March 13, 2005, 09:17 |
inf thin cells
Hi
How can you separate two regions in your mesh, in which you only want passive scalar passing from one to the other by diffusion. You don't want your active scalars to pass trough this wall. I have tried baffles and shells but none of them work as I would like them to. I have to calculate some other things at the very last layer of this interface, but when I define baffles or shells these quantities appear all messed up! I have noticed that if I define one region as solid slab then it works fine, but of course there is no diffusion of scalars in this case. I appreciate any suggestions With regards CM |
March 13, 2005, 14:46 |
Re: inf thin cells
Why can't you use porous baffles?
Thin Surface | Manu | CFX | 0 | November 29, 2006 17:13 |
Thin gap | Flu | CFX | 3 | March 30, 2006 18:40 |
thin surface | Dave | Main CFD Forum | 1 | April 14, 2004 17:09 |
Shell cells to Fluid cells | Mahbub | Siemens | 1 | October 20, 2003 16:21 |
UDF: neighbour cells, upwind cells | Dmitriy Makarov | FLUENT | 0 | February 18, 2001 14:53 |
