November 4, 2005, 13:07 |
Warnings
I have this warnings in run history
*** WARNING #038 *** UNNORMALISED RESIDUAL CANNOT BE REDUCED TO 1.000000E-06 IN EQ: PCOR ROUND-OFF ERROR RESCUE NOT ATTEMPTED; SOLUTION RETURNED WITHOUT UPDATE *** WARNING #001 *** FLUID INFLOW DETECTED AT SOME OUTFLOW BOUNDARIES WHERE MASS FLUXES ARE FORCED TO ZERO. F THIS CONDITION PERSISTS, YOUR RESULTS MIGHT BE WRONG THE OUTFLOW BOUNDARY MIGHT NOT BE WELL SPECIFIED OR THE GRID MIGHT BE TOO COARSE NEAR THE OUTFLOW BOUNDARY ** WARNING #090 *** VALUE ELOG*YPLUS OR ELOG*EFFVIS/(CAPPA*VISCOS) IS LESS THAN 1.1 AT 444 CELLS.UPLUS=YPLUS LAW IS USED. IF THIS SITUATION PERSISTS, INCORRECT RESULTS MAY BE OBTAINED. Any help should be apreciated |
November 9, 2005, 13:31 |
Re: Warnings
error 038: the pcor unnormalised residual was below the residual tolerance on the first sweep
error 001: you have an outlet boundary in an area of recirulation and flow is trying to get back in. If you get it only a couple of times at the beginning of the analysis, you can ignore it. If you get it all the time that it must be dealt with. Either change it to a pressure boundary, which doesn't mind if flow goes in or out, or move the outlet farther downstrem. error 090: your y+ values are too low for the turbulence model you are using and the near wall mesh is too fine. you could switch to a low Re model with the hybrid wall option on. |
November 9, 2005, 21:08 |
Re: Warnings
Thanks Jamie for your help. An additional doubt, when i change to pressure boundary at outlet, what is the difference in selecting: None, Zero Grad or TI/Lengh for the Turb. switch. My model is turbulent and i am using high reynolds ke with k/epsilon at inlet boundary.
WARNINGS I don't want to have | Gabriel | Siemens | 3 | August 10, 2007 17:04 |
Not to display warnings? | Yasser Nabavi | FLUENT | 3 | June 4, 2006 08:27 |
Warnings and problems with bc | evgenii | OpenFOAM Pre-Processing | 2 | February 7, 2006 07:44 |
WARNINGS | DB | Siemens | 0 | January 19, 2006 13:47 |
lots of warnings | Arnab | Siemens | 2 | January 27, 2005 15:36 |
