moving mesh problem
Old   November 11, 2005, 08:50
Default moving mesh problem
eos
Has anyone done a moving mesh analysis with both translation and rotation? for o-type mesh i used the bcs pressure, symmetry and moving wall for which i supply a user defined subroutine everything seems ok but when i start simulation the solution diverges.. any ideas why it is so?
Old   November 13, 2005, 21:14
Default Re: moving mesh problem
xhliu1
Decrease you timestep and try again.
Good Luck!
Old   November 14, 2005, 05:47
Default FSI Problems
ramesh
dears users; ist possible solve Fluis-structure interaction problems in STARCD...
regards ramesh
Old   November 16, 2005, 23:04
carno
Look into the pressure under relaxation factor. Typically it should be aroung 0.8 for such problems. Default is 1.
Old   January 27, 2006, 20:42
mary jean
what is mesh?their examples
Problem with moving mesh Sully FLUENT 7 September 11, 2008 00:38
Moving Mesh Problem Rashad FLUENT 0 August 28, 2006 04:31
moving mesh problem walid Siemens 6 April 1, 2005 17:31
Moving Mesh PROBLEM Arnab Siemens 10 October 30, 2004 02:10
Moving mesh problem Jan Majer Siemens 2 June 10, 2003 04:19
