can STAR-CD simulate a solid transfering heat ?
Old   December 28, 2005, 06:05
Default can STAR-CD simulate a solid transfering heat ?
lenson
recently I simulate a solid transfering heat.I use the gambit to build model which is transferred to star cd. type of model is setted to solid. there are two boundary conditions.after couples be done,I save the model and geometry file and problem file.All three command(save model,geometry,problem)is ok. therefore ,I go to next step.I locate the boundary area. when I locate the unstructured cell surface beeing a boundary area.I go to save three commands(save model,geometry,problem).after saving model,I also write the geometry file,but the output tells me the boundary vertexs cannot merge the cell vertex.I feel very strange.~ can anyone tell me that can star cd simulate heat transfering by solid material?
Old   December 28, 2005, 06:07
Default Re: can STAR-CD simulate a solid transfering heat
lenson
also can anyone tell me if there is another software can simulate heat transfering by solid material .additional ,is it free for download in web. thank you very much~
Old   December 28, 2005, 06:53
William Blake
It is possible.
You should go through some of the tutorials and read the manual at first.
Old   December 28, 2005, 12:00
lenson
After conducting the tutorials,there is really no example to simulate solid heat transfering.
Do you mean I should use (pro-am,pro-fe,es tool.....or sth..?)Pliz help me~ thank you ~
Old   December 28, 2005, 18:37
William Blake
tutorial 12.2 "conjugate heat transfer"
... and the geomwrite and prob(lemwrite) are the last steps of the preprocessing. the order of the steps you described was a bit strange. thats why you should run some tutorials at first.
Old   December 28, 2005, 23:47
CFDian
The conjugate heat transfer is very much possible in STAR-CD. For the error you are getting, try to merge the vertices using vmerge command.
Regards
Old   December 30, 2005, 03:13
lenson
thank you all for help. Because of tutorial 12.2 I realize the solid heat transfering settings. Really thank you all for help.~
heat resistance on solid-solid interface Bela CFX 8 October 25, 2022 16:02
how to simulate 2d solid heat conduction using CFX richard CFX 3 March 24, 2008 07:27
heat transfering between solid and fluid Benny FLUENT 4 November 15, 2004 19:20
Re; heat transfering Benny FLUENT 1 October 4, 2004 11:54
Solid-Solid Heat Transfer with Contact Discontinuity Jonas Larsson Main CFD Forum 9 September 10, 1999 15:46
