About Cavitation Model and General setting
Old   January 15, 2006, 21:30
Default About Cavitation Model and General setting
wayland
Now,I try to use STAR to simulate cavitation in a Venturi nozzle.But,I am confused with some questions,as belows:
Fist, generally,there are three MODELS in the STAR methodology,but it is said that only Barotropic Model is rational for small scale and high pressure Venturi nozzles,however, this model is very diffcult to get divegent solution.so,I need some suggestions.
Secondly,how to set the parameters to consider the compressibilty of high-pressure water.
Thirdly,STAR captures the interface using VOF method during the Free Surface simulating, and as the same during the cavitaion simulating? Though CAV+VOF=1, why STAR solve both of them using transport equations, what is these equations?
Finally, I only know the pressures at the inlet and outlet,how to set them? Especially in the compressible situation, how to deal with the wave reflection at the boundaries.
So many questions ,need helps!!!!!!!!1
Thanks a lot!!!
Cavitation Model Xavier FLUENT 4 April 21, 2008 06:04
Cavitation Model Umesh Shah FLUENT 2 June 9, 2006 01:28
about the mixture model and cavitation model lius FLUENT 2 January 11, 2006 04:55
cavitation model carno Siemens 6 December 23, 2004 23:26
use of cavitation model gdv FLUENT 7 August 7, 2002 11:48
