Rotating Cylinder
Old   June 20, 2006, 09:10
Default Rotating Cylinder
Nick
I am trying to simulate air passing over a rotating cylinder in a box domain. I've created an inlet boundary and I've defined the cylinder as a separate wall boundary. My problem is that under define boundary regions, it's only allowing me to define either an inlet velocity or a rotating wall boundary, but not both at the same time. How can I solve this, so that I have both a rotating cylinder and an inlet velocity?
Many thanks for your help.
Old   June 21, 2006, 06:42
Default Re: Rotating Cylinder
John
You can idetify each bounadry with different region number and each region can be assigned to different type such as inlet, outlet, pressure, wall etc. Then for each region, you can specify anything you want.
Rotating cylinder raul FLUENT 3 February 1, 2015 05:48
Rotating Cylinder IGE Jason Mc Beth FLUENT 0 January 23, 2008 07:02
Rotating cylinder Johnny Main CFD Forum 5 December 7, 2004 09:55
2-D rotating cylinder Ossi Siemens 1 March 25, 2002 14:34
Fluid in a rotating cylinder Fluid Novice Main CFD Forum 1 December 17, 1998 17:25
