July 26, 2006, 04:57 |
mooving mesh
Hy !-----------------------------------------------! ! ! ! 1--------1 ! ! 1 1 --> ! ! 1--------1 ! ! ! !-----------------------------------------------! I would like to have the same type of geometry where the big tube have a coarse mesh and the small inside square have a very fine mesh.. also I would like that my small square moves in the vector direction with a constant velocity ( and also that he always keep is fine mesh and outside a coarse mesh) Is it possible to do it? What should I use? Mooving mesh?
July 26, 2006, 04:59 |
Re: mooving mesh
sorry we cant see the geometry type but I explain it for yyou it is simple there is a big tube with a coarse mesh and inside there is a small square where the mesh inside is very fine and I would like that the small square mooves into my tube with a velocity
July 26, 2006, 05:11 |
Re: mooving mesh
hai,
I hope tutorial 11 (two objects passing each other) in STAR-CD manual will help for your application. shan |
July 26, 2006, 05:53 |
Re: mooving mesh
thanks But in the tutorial the mooving mesh is a block I wanted to be a fluid and the same tipe of fluid that is inside the big tube is it possible
Create fine mesh that grows to coarse mesh (Urgent | CZ | FLUENT | 1 | January 3, 2009 10:36 |
mooving mesh problem inside the cylinder | m.kantha rao | FLUENT | 1 | May 29, 2008 03:20 |
Oscillatory mesh motion setup mesh flux ERROR | jaswi | OpenFOAM Running, Solving & CFD | 5 | August 23, 2007 04:41 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
Mooving Grids | Romuald Skoda | Main CFD Forum | 5 | August 22, 2000 07:44 |
