Unsteady flow CCM+
Old   November 13, 2006, 05:28
Default Unsteady flow CCM+
James
I am modelling the unsteady flow throught a racing car's airbox, which is running a presure inlet and mass flow at the outlet.
I have engine data which plots time against mass flow rate, but I dont know how to get CCM+ to communicate with the data/script file.
Any help will be mush appricated! Thanks
Old   November 13, 2006, 06:58
Default Re: Unsteady flow CCM+
Ben
load in an external table using the table tool (in the tools folder) then set your boundary specification to table and not constant
Old   November 13, 2006, 07:29
James
Thanks, I am relatively new to this,
What file format should the table be? I just have two varibles, so would a .xy table be ok
Old   November 13, 2006, 07:50
Ben
yup, two columns separated by a space should do
Old   November 13, 2006, 11:46
James
thanks so much, but when i run the simulation an error appears stating "non-existant dataname in table"
the table is plotted (timestep pressure_at_timestep) and the "constant" under the pressure outlet to Table(time) has been changed etc.
Also, is it possible to run a pressure inlet in CCM+?
Thanks
Unsteady Flow Duc FLUENT 1 January 16, 2017 06:26
unsteady flow Sumeet FLUENT 0 September 10, 2005 11:09
unsteady flow suresh FLUENT 0 April 4, 2005 23:47
unsteady flow George Main CFD Forum 1 July 8, 2002 07:42
Unsteady flow Enrico Main CFD Forum 0 February 26, 1999 06:40
