proam problem in Star 3.20 Linux
Old   February 6, 2007, 05:37
Default proam problem in Star 3.20 Linux
David Baker
When I run proam or esaero by command line in Linux, only pro-star comes up and there is not any AutoMesh menu in the menu bar. So I can not run proam or other es-tools. What is the problem?
Also when I run starlaunch to make an icon in desktop, I get an error message. I use Linux mandrake 9. Is there any solution?
Old   February 6, 2007, 07:46
Default Re: proam problem in Star 3.20 Linux
Ben
1 - upgrade to 3.26 for gods sake, 3.20 is older than my mother.
2 - the menu is advanced -> automesh
Old   February 6, 2007, 08:40
David Baker
1- I can not upgrade. 2- I did not understand.
Old   February 6, 2007, 09:51
Ben
1 - why not? 2 - On the menu bar you should have a menu labelled advanced, in that you should have pro-am
Old   February 6, 2007, 23:57
David Baker
Which menu bar? You mean in pro-star or starlaunch? If it is starlaunch I have some problems to run that.
Old   February 7, 2007, 17:23
Postmaster
in prostar, select the menu "Advanced" and then click on "Automesh"
to use proam you must be familiar with prostar and you must attend the advanced training course. You will not be able to use proam without the training and might take 3 month what you can actually do in a day.
If you cannot upgrade it is not good news as well.
Meshing Problem Proam Phil Siemens 0 June 2, 2007 12:03
proam tetfix problem tom Siemens 1 March 15, 2007 17:02
iges-prosurf-proam-prostar-star elvis Siemens 6 October 17, 2005 04:35
A problem with Star-cd v.3.15 for linux Gstas Siemens 4 December 9, 2002 20:52
Problem with proam Mir Siemens 2 March 26, 2002 04:54
