April 23, 2007, 10:13 |
error in Star-cd linux 4.02
I have a model with these files: 1- abc.inp 2- abc.cel 3- abc.vrt When I read the model in star-cd 3.26 linux, I don't get any errors when I check the model. But in star-cd 4.02 linux I get many errors when I check the model(all errors). 1- What is the problem? 2- are files format different in 4.02? Best Regards, David |
April 27, 2007, 08:45 |
Re: error in Star-cd linux 4.02
what errors do you get?
April 28, 2007, 01:56 |
Yes, you're right - .cel file format has been changed from v.3.x to v.4.x
April 28, 2007, 06:31 |
How should I convert the format?
April 29, 2007, 02:40 |
There is no official converter. There are two ways you can consider: 1) ask CD-Adapco (I don't belive that they don't have a converter for themself!), but you'll probably have to be persistent to explain, why do you need it; 2) you can try to write the converter yourself (that's the way I'm considering now). For the second way you'll have to create two identical models in v.4 and v.3.26 and write them as .vrt and .cel files, then compare them. The only problem I can see is with polyhedral cells - they can have shapes illegal for v.3.26.
April 29, 2007, 12:58 |
Just read it with v32 and save the *.mdl file. Later read this file into v4.
June 16, 2007, 09:31 |
In windows vesion it does not work. Is there any other solution?
Which Linux for Star-cd 4.02 ? | David Baker | Siemens | 8 | March 12, 2007 03:08 |
Linux Star run error message | usker | Siemens | 1 | March 10, 2007 09:39 |
star-cd on Linux | Ak-47 | Siemens | 15 | January 10, 2007 15:05 |
star-cd and Linux | vittorio faluomi | Siemens | 8 | November 2, 2000 15:40 |
Star and linux | Caroline | Siemens | 10 | April 10, 2000 11:39 |
