small size cell problem(moving mesh)
Old   May 12, 2007, 23:27
Default small size cell problem(moving mesh)
Elyor
Hi guys, i generated moving mesh for sliding vane pump, in order to change cell position i used filling. when i run the solver solution diverge after some iter. then i checked result velocity is a very hight in smallest size of mesh(0.001 mm) i think velocity difference in biggest cell(0.41mm) and smallest cell(0.001mm) is too big that's why solution is unstable. how can i decide smallest cell, please advise.
Old   May 12, 2007, 23:45
Elyor
Hi guys, i generated moving mesh for sliding vane pump, in order to change cell position i used filling. when i run the solver solution diverge after some iter. then i checked result velocity is a very high in smallest size of mesh(0.001 mm) i think velocity difference in biggest cell(0.41mm) and smallest cell(0.001mm) is too big that's why solution is unstable. how can i decide smallest cell, please advise.
Limit on maximum cell size to minimum cell size ratio albcem OpenFOAM Running, Solving & CFD 2 October 17, 2011 12:00
Gambit: mesh size to small??? Ralf Schmidt FLUENT 1 January 28, 2006 01:26
Mesh/Cell size Jamcam Main CFD Forum 5 July 12, 2004 08:43
A 2-different size mesh problem Luc FLUENT 1 January 10, 2003 16:13
Problem in TE model and cell size Mir Siemens 2 December 11, 2001 09:46
