Source Terms in Star-CCM+
Old   November 24, 2007, 07:50
Default Source Terms in Star-CCM+
mk_mat
In Star-CD you have the option to add source terms for Mass, Momentum, Scalar (Species) etc...
but in ccm+ if from physics you select "Multi-Component Gas" we will have the option of source term for Momentum, Species but not Mass! and if you select "Gas" you will have the option of source term for Mass, Momentum but not Species! In other word, you cannot have all of them together! how is that possible, is there any explanation for that?
Old   November 26, 2007, 03:50
Default Re: Source Terms in Star-CCM+
Richard
If you have a single-component gas, you only have one "mass" equation (the continuity equation) so you only specify one mass source. If you have a multi-component gas, you have N species equations plus the continuity equation. In STAR-CCM+ you specify the N species source terms, and the source which is applied to the continuity equation is calculated internally as the sum of these sources.
STAR-CD is different because it has the concept of a "background fluid", so when you think you have N species, you actually have N+1.
Old   March 13, 2012, 08:14
itsme_kit is on a distinguished road
Originally Posted by Richard
;174815
Hi
Once I got the graph where flow rate against pressure from modelling of pump
How can I get this result as a source term in to Star-ccm for another simulation?
Thanks
itsme_kit is offline   Reply With Quote
Source terms Virginie FLUENT 1 December 19, 2007 02:00
Source terms... again AdN FLUENT 9 April 27, 2006 04:34
Source Terms Rajan CFX 1 March 14, 2005 09:26
UDF source terms Andrew Garrard FLUENT 1 October 30, 2003 10:48
UDF for source terms Tom FLUENT 1 April 26, 2002 01:13
