External Aerodynamic Simulation+negative densities |
February 18, 2008, 03:51 |
Hi all, I would like to know the following queries on STAR-CD:-
1) What boundary conditions on each face of the bounding box need to be given for simulating the aircraft encountering a large side-slip angle simultaneously with angle of attack. 2) When polyhedral cells are created and inviscid option is selected for solving, the solution diverged and the solver reported that the model got negative densities. I didn't understand what is meant by negative densities and why it is reporting like that. I will be pleased if somebody answers the above questions as soon as possible. thanks and regards, rvramkumar. |
February 18, 2008, 15:27 |
Re: External Aerodynamic Simulation+negative densi
it means you have bad polyhedral cells in your geometry. Try the same case but with the trimmer model.
February 19, 2008, 04:18 |
Thanks. I'll try with trimmer model. Nevertheless, When the mesh is checked, it was not giving any errors. Why this ambiguity?
negative densities | john | Siemens | 0 | March 19, 2008 06:32 |
negative densities | Riyaz Ahamed | Siemens | 2 | August 14, 2007 01:47 |
Negative densities!!! | Nalleli | Siemens | 5 | August 31, 2005 06:38 |
negative densities. | Mihir | Siemens | 4 | December 9, 2002 21:04 |
negative densities | Fabrizio Grieco | Siemens | 4 | October 30, 2000 01:47 |
