Which Linux distribution?
Old   August 3, 2008, 22:47
Default Which Linux distribution?
Luke
I have been trying to use Star-CD on Windows for a while now and have decided to switch over to Linux because of the fact that the university now has es-ice. Which Linux distribution would you recommend for a new Linux user? Cheers
Old   August 4, 2008, 04:19
Default Re: Which Linux distribution?
Anton Lyaskin
The one which is officially supported by Star-CD These are RedHat and SuSE/OpenSuSE. Try searching this forum - I remeber people managed to make it running under some other distributions.
Old   August 4, 2008, 04:38
Luke
Thanks for the reply. Would Scientific Linux be supported as a derivative of Red Hat?
Old   August 4, 2008, 07:43
allan
Luke
Go for suse or opensuse, you'll save yourself loads of grief. Here we use suse 10.0 or opensuse 10.2
Haven't had any problems
allan
Old   August 4, 2008, 08:08
Luke
Thanks for the tip Allan!
Old   August 5, 2008, 09:49
usker
Any OpenSuse Linux release works well. We use OpenSuse 10.3 and even OpenSuse 11.
Regards
Old   November 5, 2008, 08:47
allan
Hi Usker
Did you have any problems using suse 11? We've changed to an intel 64 bit dual core machine with suse 11 and I can't even run flexlm, tells me it's not been initialized properly.
Any ideas
thanks
allan
Which Linux distribution should I use matthias1 OpenFOAM Installation 6 September 10, 2008 04:46
Which linux distribution hsieh OpenFOAM 11 June 27, 2007 06:46
Can Starcd for linux run in Linux Debian? help deisler Siemens 1 February 28, 2007 04:27
moisture distribution vinod kumar FLUENT 2 November 22, 2005 03:22
Help!! About distribution of h2 in the air Wenjuan Siemens 2 February 16, 2005 03:01
