remedy for ensight
Old   August 21, 2008, 03:10
Default remedy for ensight
remedy
why is it very often my pc crashed when exporting results into Ensight? Is there a known way to fix this problem??
Old   August 21, 2008, 08:47
Default Re: remedy for ensight
Kevin Colburn
Which version of Prostar are you using? Standard release of v3.26 does have a bug in it causing Prostar to crash when writing EnSight files. I believe that patch 11 to v3.26 solves this problem.
Old   August 21, 2008, 23:29
remedy
ok thanks for that info! it's v3.26.004.
Strangely i had lesser problem on this version to write for Ensight a few weeks back.
Old   August 23, 2008, 06:18
Reza
I've had in the past also similar problem. It's a memory problem. if you over define MAXCUT MAXSC1 MAXSC2 and MAXSC3. You don't really know exactly how much more memory prostar can still function properly (without crashing), because the prostar keeps telling you to increase the memory without saying "At least xxx"
since then, I manage to write my ensight output manually on the command. It works....!! almost always...
just type HELP ENSI on the command line, then you find out how to do it manually. It gives you also an example.
Cheers, Reza
Old   August 23, 2008, 13:33
Kevin Colburn
It also helps to be on a later version of Prostar. Early versions of 3.26 were a problem within the ensi routine in Prostar. V3.26 patch 11 solves most all of the problems experienced previously. Definitely getting comfortable with the setwrite and the ensi commands, you can write out exact what you want.
Old   August 26, 2008, 03:30
remedy
ok this sounds nice, so i should just type setwrite in the i/o window? what other commands should i use in there?
Old   August 26, 2008, 06:43
Kevin Colburn
You have several options: 1. You can use the NavCetner -->export --> to EnSight. This is quite easy and straight forward, but also not a lot of control. I would use this simple method first, and see if this gives you what you want. 2. Alternatively, you can use the "setwrite" command to build a setfile containing the parts that you want to have in EnSight. You can then use the "ensi" commands commands in combination with getc or getv commands (and operate commands) to generate the variables that you would like to export to EnSight. This is a slightly more involved process, but allows you ultimate flexibility in parts and variables written to EnSight. Check out : http://www.ensight.com/screencasts/S...ate_Export.htm
Ensight Mattijs Janssens (Mattijs) OpenFOAM Post-Processing 77 November 5, 2021 11:33
Ensight Jo Siemens 1 May 12, 2010 08:45
Using Ensight anyone? vivek FLUENT 1 May 12, 2010 08:40
Ensight export Fred Siemens 0 September 12, 2005 04:22
