January 14, 2009, 07:59 |
Please Help Me
Hello I am modeling a smooth straight channel in Star CCM+. I want to find out the average Nusslt Number on different walls of the channel like side ad bottom walls. Also How can I find the total average Nusslt Number of the channel flow? Reply will be appriciated. Regards Waseem
January 15, 2009, 01:19 |
Re: Please Help Me
check out this http://www.adapco-online.com/adapco_...frontpage.html
January 15, 2009, 10:07 |
Re: Please Help Me
Its a fully loaded website with a lot of info..... can you please specify the related artical?? Thanks
January 15, 2009, 19:33 |
Re: Please Help Me
1. Create area averaged report(s) of heat transfer coef field function on the surface(s)
2. Create new field function(s) called Nusselt # and define is as per its formula using the field function(s) created by the above report(s), fluid conductivity and char. length 3. Create new 'max' report with N# as the field function and run this report. |
January 15, 2009, 21:18 |
Re: Please Help Me
http://www.adapco-online.com/adapco_...frontpage.html ->Dr.Post->Calculating->Calculation of Nusselt Number
January 16, 2009, 07:20 |
Re: Please Help Me
Ping This was very helpful: In CCM+ there is a field fucntion of Nusttle number. Averaging it directly would give the same result, I assume. Waseem
