January 21, 2009, 06:33 |
VOF error when initializing
When initializing turbulent flow for VOF calculation, solver get me this error:
"Warning: Initializing turbulent flow with density unavailable in fluid! Density of 1 kg/m^3 assumed for computing initial turbulence quantities." What is it?? How can I avoid this error?? Thank a lot |
January 21, 2009, 07:12 |
Re: VOF error when initializing
There's no problem, simply the turbulent flow field will be initialized using a standard density value. Next the turbulent flow will be calculated coerently with the exact density of the fluid...
It's just the initialization |
January 21, 2009, 08:07 |
...ok, but after a few iteration simulation diverge and the iso-surface at VOF=0.5 assume unphysical shape....
With laminar model I don't have this problem! Any idea?? |
January 21, 2009, 08:19 |
what kind of simulation is? Steady, transient...and also: underelax, boundary, initialization field/functions...?
January 21, 2009, 08:27 |
Simulation is VOF unsteady, underelax low (0.4, 0.3 etc..), wov wave first order, 6DOF frozen for computing hyrodynamics forces on a ship hull.
Similarly of the demo from CD-Adapco for DFBI, i set the correct bondary conditions, but i change turbulent model...so from laminar to k-omega. Mesh is ok, with B.L.y+=50. Time step 0.01s Do you have any experience on this problem? |
January 21, 2009, 13:27 |
Are you using first or second order time Discretization?
January 21, 2009, 14:08 |
second order
January 21, 2009, 14:09 |
and first order for time!
January 21, 2009, 16:00 |
Try changing the turbulence specification to K + Epsilon on both the initialization and the inlet.
January 23, 2009, 07:18 |
if it doesn't work try initializing the sim with first order scheme...then switch to second order later
It's a general tip, I'm sorry but I don't have experience in this kind of sim...but the initialization it's similar to other ones... |
February 3, 2009, 19:35 |
#11 |
Have you tried lowering the time step? Are you using ccm+ or v4? In v3 I always faced problem when the time step is that large (0.01s). In v4 this seems less a problem. I think I read on the manual or somewhere VOF is not yet able with k-omega or other turbulence models. For DFBI, it might not even able to handle k-E but I'm not sure. BTW, I'm curious to know how long it takes you to complete this run.. the elapsed time I mean... when you complete this job later. (Just curious if you dont mind).
February 11, 2009, 11:26 |
#12 |
I think VOF and turbulence don't go together in STAR-CD. The software calculates granular variables and the only correct choice there is laminar flow.
error while initializing | mahi | FLUENT | 1 | November 26, 2008 05:11 |
Error while initializing a case | summer | FLUENT | 0 | April 15, 2008 16:22 |
Initializing different block in 3D | star123 | FLUENT | 1 | April 8, 2008 20:57 |
initializing the solution | Thiyagarajan | FLUENT | 2 | June 6, 2004 02:48 |
UDF for initializing VOF | Ray | Main CFD Forum | 0 | November 11, 1999 11:29 |
