Couple two meshes
Old   April 28, 2009, 07:12
Default Couple two meshes
wei
wei
wei is on a distinguished road
How to couple two meshes if there is a small gap exist? (please see figure http://www.whlam.com/e6.jpg )
wei is offline   Reply With Quote
Old   April 29, 2009, 04:46
Anton Lyaskin
A_Lyaskin is on a distinguished road
You can either change the default tolerance for couple creation or remove the gap.
The first way is more simple but this can result in wrong cells assigned to couples (in your case, for example, from the second layer of fine mesh instead of the first one).
The second way is more complicated - you'll need to create shells on top of coarse mesh (mesh 2), select the vertices at the bottom surface of fine mesh (mesh 1) and project the to newly created shells with VPROJECT command.
A_Lyaskin is offline   Reply With Quote
Old   April 29, 2009, 05:15
Smile
wei
wei
I use the VPROJECTION to eliminate the gap. It is working.
What commands should I use to couple the fine mesh to the coarse mesh?
Old   April 29, 2009, 06:42
Anton Lyaskin
CPCREATE, to create couples
And don't forget to allow partial boundaries for your couple type.
Foreseeing your question about partial boundaries - please study Tutorial 14. Studying tutorials will really help you, trust me!
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 07:06
Coupling meshes in v15 canfield OpenFOAM Running, Solving & CFD 0 December 22, 2008 08:14
Couple error Yehia Siemens 3 January 25, 2007 03:58
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 03:33
