HSMAC (Highly Simplified Marker and Cell) method |
April 20, 2018, 05:47 |
ulfa
Rep Power: 8 |
Dear, everyone..
I am doing a numerical investigation of unsteady heat transfer in a Newtonian fluid occupying a square cavity. I solved numerically using HSMAC (Highly Simplified Marker and Cell) finite difference approach as the governing dimensionless equation. The fluid flow is simulated with a heating on vertical side (left) wall and a cooling on vertical side (right) wall. I used Fortran programming to get the data and it has been done. but my problem is the data are dimensionless, so need I return those data into dimension term before drawing?? hopefully someone can help me.. thank you. |
heat transfer, hsmac, newtonian fluid |
Boundary Conditions on Divergence in Marker and Cell (MAC) | FluidFox | Main CFD Forum | 9 | August 2, 2016 12:59 |
Marker and Cell Grid | thatdiverguy | Main CFD Forum | 0 | January 3, 2015 14:57 |
matlab code of marker and cell method for solving 2d incompressible navier stokes eqn | sgangarapu | Main CFD Forum | 1 | August 28, 2013 10:33 |
Marker and Cell Method - a code to look at it? | kujret | Main CFD Forum | 0 | March 3, 2013 04:14 |
Marker And Cell method (MAC) | Albert Badal | Main CFD Forum | 0 | February 27, 1999 19:53 |
